the idea is good just quality of connectors is poorIt should not be necessary to tamper with the connectors, but I really prefer them like that than soldered to the board. As they are, if something happens to them it would be a trivial fix, definitely easier than desoldering. Their choice also opens the door to install, for example, the new 12 pin connector if you wanted (I guess that Gigabyte took that route just to have more freedom in this regard). Finally, with their design, when you plug the cables (or if there is tension after plugging them) you are not stressing the PCB, but a cheap external component.
Yeah that's not ideal. Probably easily fixable, maybe the retention clips on those pins have gotten a little bit bent and they drop out too easily.
Managed to sort out the pins, I AM BACK IN ACTION BABY!
First I just wanted to RMA it, and be done with it, but seeing some other people tackle the issue, I was like, I can do this ****. Nevermind it's a £1600 card, easypeasy. You can imagine my relief when the card booted up properly. Now I've finished some good old testing and it still holds, so I may just avoided bricking it, looks like.
I had to take off the backplate and unscrew the connector to be able to properly refit all the pins that got pushed back. First I tried through the ventillation holes on the backplate, but two of the pins wouldn't budge, so I had to take it apart. After reassembly I tried to make sure they are all in the middle of their socket, and I also fiddled a bit with the female power connectors on my Corsair PSU, so the couplings are not too tight, so there is less chance of them pushing back the pins again in the GPU connector.
The quality of the connector is abysmal really, this is something I remember from the old days of IDE HDDs and CDROM drives, when the pins would move around like they don't belong there. I don't know how on earth this could pass quality control. Just comparing with the connector on my old GB 1080, that's a proper thing. This is awful.
congrats great job enjoy the cardManaged to sort out the pins, I AM BACK IN ACTION BABY!
Hey all,
I'm talking to my HQ and we're looking into the reports.
IMHO there is no room for molex connectors like this in modern computer components,they are among the worst connectors i have ever seen..they are the long lost brother of the tamiya connectors
I RMA'ed for exactly the same thing. Had my GB Eagle OC card for 4 days and it started having issues with power and black screens etc. Noticed 3 of the pins were lower than the rest.
I've been without it since returning to OC for just under 2 weeks now. So the last thing I want to go through is this again when I get my new GB OC card.
Being aware of this issue, I've actually purchased PCIe extensions to fit on the card so that I don't have to continually apply stress to the connector.
When I need to remove it from the case in the future or disconnect the GPU from power etc. it will be from the extension.
If it continues to be an issue then I'll return it and replace with another brand once shortages are resolved or I'll go with Big Navi if it's just as good as the 3080.
Hopefully GB will have a fix / replacement unit to offer people that have purchased the card by that point.
To be honest, I don't see the point of it - I'm sure there must be one, but it is lost on meI really do hope Gigabyte revise the connection box going forward.
We have investigated the issues that have been reported and have a solution to fix any cards that have developed lose or faulty power pins. Any customers that have experienced the same power connector problem as reported on this thread, please contact me directly and I will arrange to have the card fixed with a new connector as quickly as possible.
[email protected]
