- 26 Feb 2010
- Surrey, UK
Do any manufacturers allow RMA for coil whine?
14 days u can return for no reason.
Um, what?rma the card
Is there a way to undervolt the 3080's? If you can reduce the power draw it might make the coil whine go away.
I really hope so cause that’s what I’ll be picking up soonSo a 850W PSU is safe? Right?
At least your PC runs, unlike this poor sap
https://www.reddit.com/r/nvidia/comments/j3j8yq/3090_and_asus_antisurge/
So I got my MSI 3080 Gaming X Trio today, I got very lucky when ordering off ocuk, completed my order at 14:05. Thankfully this isn't a crashing thread (not yet anyway)
So I installed the GPU and drivers, tested some games and was very happy with the performance boost, all was going well until I took my headset off and heard the screeches coming from my PC. I had completely forgot this happened to me before, when I upgraded to a GTX 1080 with a very old corsair PSU and now it's happening again with a 2 year old EVGA G3 750W
I've tested by using a toilet roll tube and putting it to my ear and going around the GPU and PSU including the back of the PSU, im 90% sure the sound is coming from the PSU as the loudest noise was coming from the back where the I/O switch is. Is there any other way to test this?
What's the reasoning behind this? Is it just because the PSU is under a much bigger workload now? Probably close to its limit?
I have a 2700X OC'd to 4.1ghz, that probably doesn't help either.
Lastly, unless anyone has a reason or a test for me to perform to prove it isn't my PSU. Any recommendation's for PSU's?![]()
What hz is their monitor? I’m pretty sure coil whine is louder in higher frame rates, my monitor is 165hz so even with vsync on it’s still producing high frames. Whereas if your partner’s monitor is say, 60hz 4K for example, that might be why the whining stopped.It's gonna sound like a weird one, but my partner got their MSI 3080 Gaming X Trio installed yesterday, and when in certain games noticed coil whine from his PSU too. Strangely, turning V-Sync on in the affected games stopped it from making the whine O_o
I play at 1440p and I noticed when I bumped my resolution scale to 200% in a certain game, even though my gpu is working harder and even though it’s not true 4K or anything, the frame dropped to like 80-90 and the whining was a lot quieter. Although I haven’t tried capping to 60fps, just for tests sake.
cheapest best option is probably the superflower leadex 3 https://www.overclockers.co.uk/supe...old-modular-power-supply-black-ca-062-sf.htmlWhat’s your SO’s PSU model and wattage? If you don’t mind.He plays at 1080p on a 144Hz monitor; this may be why it was okay for him O_o. Worth a try capping it for tests sake though![]()
