What’s your SO’s PSU model and wattage? If you don’t mind.
He has a Corsair CX750M which as the name suggests is 750 Watts
Same as mine basically.. Tell him he’s a !@#@%#! £&?!... but Im glad he got it fixedHe has a Corsair CX750M which as the name suggests is 750 Watts
Same as mine basically.. Tell him he’s a !@#@%#! £&?!... but Im glad he got it fixed![]()
Looks like my luck is awful, nothing new thereMy Corsair 650W (RM650x) is running my 3080 and i9 9900k perfectly fine so I would be surprised if a decent 750W was having problems
Then run it like this. As long as your PSU isn't garbage (which it isn't), it'll be fine as the cable must be spec'd to carry upto 300W (assuming it's a pair of 6+2 pin PCIe cables). Furthermore, with 3 8pin cables and the PCIe slot, that's a total of 525W of capacity before going overspec and given that the 3080 doesn't draw that, you'll not be pushing the cables to their limits.Okay so I just tested it with one regular VGA cable and one VGA daisy chain cable, just to see, and the coil whine has actually been significantly reduced.. I've heard a lot of reports to stay away from daisy chaining with these 3080's but, the coil whine is def less obvious when I use one although it is still there.
So a 850W PSU is safe? Right?
@tyler_jrb yeah man, my pc is like a meter away from me so that helps blocking out the sound thankfully.
So am I right in saying once you have coil whine, it’s more or less impossible to get rid off without running the risk of completely breaking your PSU by glueing the coils?
Thanks dudeThen run it like this. As long as your PSU isn't garbage (which it isn't), it'll be fine as the cable must be spec'd to carry upto 300W (assuming it's a pair of 6+2 pin PCIe cables). Furthermore, with 3 8pin cables and the PCIe slot, that's a total of 525W of capacity before going overspec and given that the 3080 doesn't draw that, you'll not be pushing the cables to their limits.
Yeah it is very irritating but thankfully mine isn’t atrocious an my computer is far enough away for the sound to be blocked out lolIts hard to get rid of, even glueing the coils may do nothing (ive tried before).
Best bet is another PSU either replacement or another model. Or if you can attempt to isolate the noise somehow. Or say undervolt your 3080.
I know how frustrating it is though hence why my pc is now several feet away in a wall cupboard. Honestly there are weeks on end where I don’t even look at it anymore. Do miss it on the desk but I don’t miss the whine.
I am truly sorry for thisI've got an EVGA 750 P2 and that's giving me coil whine as well. Hadn't noticed it as PC is under my desk and I wear headphones, only checked because of you and now I'll hear it forever grrrr!
Could it be capacitor whine?
I rma' d a Corsair PSU for mild whine and they were good about it. 2011 though.
I'm currently trying to learn how to undervolt, I don't really understand it lol but I think I'm starting to pick it up, I never really use curves.Try undervolt it with Afterburner? That might help.
I’ve done that just out of curiosity with my ASUS TUF 3080, down to 0.86v and still got core clock set to 1950MHz and runs no problem at all!
Now uses a fair bit of less power which is nice, for the same performance!![]()
