These screens are very bright
To achieve 120cd/m my brightness needs to be 13
Quite dark that...mine is on 35 from 62 factory!
i had no flicker at all until the last 2 geforce graphics drivers so i dialled back to a graphics driver before that and the flicker has now gone im using 452.06 with firmware 1006.2 on the g9My flicker is still there. It looks like it’s what’s been described elsewhere and is caused by the gsync doubling the us of the screen at some points which in turn causes the screen to slightly get more bright. So - can this be fixed with firmware or drivers? I don’t remember my last one having this issue to be honest - it’s subtle but quite irritating once you notice it. It only seems to happen when the fps is a long way off the monitor native hz . Thoughts everyone?
edit: have noticed that iracing now seems fine, but assetto cc flickers a lot and if you put the info screen on the monitor you can see the refresh rate of the monitor going up and down. Not so with iracing even though it’s FPS is wildly fluctuating too. I’m betting this is a driver/ firmware issue.
I'm using the club 3D DP 1.4 cable. I used to get flicker on my Alienware, bought this cable and its been fine.
https://www.amazon.co.uk/Club3D-CAC...1&keywords=club3d+cable&qid=1601817550&sr=8-1
What's the point of the large '240hz!' in a circle at the top of the OSD? I had assumed it was a live report of the current GSync refresh rate, but on clunkily navigating to the 'Information' menu item (that also shows firmware version) it shows the actual rate which is different and matches the Windows config.
Does the big circle just show the max rate you have selected in the menu? That's completely pointless.
That information menu item is clunky to get to and obtrusive, is there some Windows tool that will overlay GSync refresh rate in the corner? I have Fraps showing fps but I also want to confirm what the OS/GSync are doing. I found an overlay option in the NVidia control panel but it just says 'GSync' on the left.
I see the rainforest has the G95 in stock for delivery Wednesday, anyone ordered from there and know which month the units are built? I'm tempted to go with them as with the problems reported here I'd prefer to have a very easy return process...
The one I received from them last week was an N5 ie May build! It had the bezel light bleed issue. My recommendation is to purchase from OC or Samsung direct as their returns process is better than the one I’m experiencing from The rainforest at the moment - it’s a large box and Amazon don’t use the best couriers for this type of equipment. Samsung use DPD and it was very pain free to return and get one delivered.
