- 30 Sep 2020
I'm position 11 and not heard anything yet. I'll post once I hear something.Not yet, but then I’m #26 so I guess you will probably hear before me. Let me know how you get on!
Msi's due in according to latest, come on palit! Pull your fingers out your bums and send us some cards![]()
Hi, one shipment was made last Tuesday and another new shipment will be heading to the UK this Friday. Hopefully local shops will be restocked in the next 2-3 weeks. Cheers!
https://www.facebook.com/photo.php?fbid=10164393799670541&set=p.10164393799670541&type=3Care of a UK distributor, not directly to OC. Check Gibbo's post at 14:57 on the 23 September https://forums.overclockers.co.uk/t...deliveries-how-to-cancel-your-order.18899277/
Sorry new to this forum, this was in response to someone suggesting ASUS shipped directly to OC.
Folks at Palit suggested
So I'll try no to think about it for another 15-20 days![]()
That statement just reads full of snobbery, given the choice I'd have a FE card over any AIB....I just can't get one. (shame on me I guess).
Hopefully you can see the facebook ASUS DIY page but ASUS UK have said they frequently send stock to OC in response to a Strix question.
Will give it a go lolAhhh ok, I could just about make out the text response before the Facebook login popped up (don't use Facebook). Can you get back to them and ask for at least 1000 cards of different flavours for tomorrow please.![]()
Not referencing the Strix specifically, but I believe OCUK may have separate stock for PC builds (as hinted at above by a forum member).
If you go to the their Custom Gaming PC configurator, you can select a *build stock* Gigabyte 3090 that you can configure.
I think it makes a lot of sense tbh and for all I know (I know absolutely zero about how they operate) the build stock could simply be separate stock that OCUK receive without any retail packaging and therefore is separate from the main consumer deliveries. Maybe almost like a reviewer channel.
As I said though, I know nothing about their system nor the way they operate.
Hi anyone hear when they next get a shipment in for the asus rog strix oc or rough date when they expect it if not i understand i know how crazy it is to get updates at the moment thanks again![]()
