Thanks for the heads up. What did you use to cut and deburr the tubes - I have no experience with cutting copper.Thanks! I bought a lot of cooling bits (tubing included) from the usual Chinese sites.
A cheap adjustable pipe cutter and the usual deburring tool with some sandpaper. It's surprisingly easy - just insert the tube, tighten the cutter, and rotate. Continue to tighten the cutter whenever it feels loose and you should end up with a nice clean cut.Thanks for the heads up. What did you use to cut and deburr the tubes - I have no experience with cutting copper.
Thankswow this is amazing, love it
Yeah, I was debating changing to micro/atx, but I never use any other expansion cards other than a graphics card, and 16gb is still enough ram for gaming, even when 32 is needed I can just swap to 2 x 16gb sticks.Motherboard looks lost in there
Nice build though mate.
Thanks
Updated again tonight with some new fans, 2 colour loop and a flow meter
ThanksIt's a Bykski one, i have both versions installed. One which is flow only and the other is flow and temp.Would you mind me letting the flow indicator brand here please? Assuming that is what it isThanks
