Ah that's good thenOf course. Its same store.
I already took the back out of mine as it was making my xb1x sound like a hairdryer, it made a difference as I could feel the heat venting out the back and up the wall, but it still got very toasty in there (I always leave the door open when in use)Mines going on it's side, but I took the back out of the cabinet so it should have plenty of ventilation!
My concern is it has been stated the series x still pumps out heat when in standby (to be fair my xb1x felt hot in standby as well) this would be a worry with the doors closed overnight etc, i can see myself getting a small stand to put it on.....or am I being paranoid![]()
Random question but my soundbar has pretty much gone pop and I need a replacement. Does the soundbar also need to support HDMI 2.1 if I'm planning on getting a 4k 120hz HDMI 2.1 TV somewhere down the line? I don't really want to buy a soundbar that is already redundant. Any advice appreciated.
Good to know thanks.If you buy a hdmi 2.1 TV it should have E-ARC. That'll let the TV use HDMI 2.1 features for video and then use a hdmi from TV to the sound bar rather than using passthrough (if that makes sense!).
Same here that's why I'm thinking of placing mine outside, RDR2 sent mine into overdrive, come to think of it Forza Horizon 4 used to shut it down as wellI put the One X inside the TV cabinet and it overheated playing RDR2, just shutdown, had to move it out!
Hopefully these will be ok.
Dunno, that sounds to me like you have either a serious console issue or really bad ventilationSame here that's why I'm thinking of placing mine outside, RDR2 sent mine into overdrive, come to think of it Forza Horizon 4 used to shut it down as well
