Some nice power sippers in the 4000 series APUs.Which 3000 or 5000 series slot chips you suggest then? One's using zen2 or 3 tech, I am aware of the zen+ variants.
No worries. Hopefully that's a good direction for you to research the options for your specific requirements.Thanks I had a look and they look a good bet, is nice to know they an option. I think AMD eats intel for breakfast right now on power efficiency.
A vendor has decided to start making AMD NUC's hopefully they use one of these 4000 series chips.
You will probably be able to run 5900X at 50 watts, but a 4750G is a beast at 40 watts.
4750G doesn't exist as a retail DIY product or is OEM exclusively..
You can buy them with a 12 month warranty. They exist if you want them too.
I found it, yes, it's available. It's a 65-watt product, though..
Alternatively you could just buy the actual 35w part, the 4750GE.
I was gonna say...Alternatively you could just buy the actual 35w part, the 4750GE.
The Ryzen killer (Alder Lake) has been pictured, boy is it a big CPU!
https://videocardz.com/newz/exclusive-intel-alder-lake-s-cpu-pictured
This is likely to be Intel's next Sandy Bridge moment, restoring normality and eclipsing anything AMD can offer. Huge number of pins, so massive IO bandwidth - think DDR5, PCIEv5, more lanes from CPU. Jim Keller has left AMD, I doubt there any many more cherry's to pick to improve on Ryzen much further.
The big-small architecture (small atom like cores couple with the big ones) will get software optimisations due to Intel's massive influences, and will echo in a new era for power efficiency and performance.
Hopefully AMD can fight back with Zen 4, though I wouldn't expect that they can compete with Jim Keller's Alder Lake design.
Hi Ryan, how's it going?In all seriousness though it might do ok in 8 core workloads but it's going to get stomped by a true 16 core. I could see it being good in a laptop with varied workloads but not so much for a desktop.
IMO Alder lake gets stomped by Zen. Big little sounds like a windows scheduler nightmare waiting to happen. Given it took the best part of 2 years for the scheduler to be sufficiently "fixed" for Zen I cant see this big little being better in any meaningful way if anything it's much harder to schedule for. The fact that it is a Keller design is interesting if it actually is the fruits of his labour, given the timing you would expect at best that Alder lake was basically done by the time Keller Joined so we shouldn't expect Keller magic in Alder Lake. In fact I have heard it said several times that the Ocean Cove cores (those of Alder Lakes successor) are the most likely to be Kellers work.
