Damn, I never knew that, probably should have done some more research!You won't get the 2600x to run at 3,600. Max is typically 3,200 and even that can be troublesome.
Thanks again.@Slinky69
The below might take about 20-30 minutes but it should net you easy performance.
Step 1: Taiphoon to obtain XMP profile
https://www.reddit.com/r/Amd/comments/cw3cn0/psa_use_thaiphoon_to_exportimport_your_xmp/
You can stop at step 4 of the reddit thread above. Once you do step 4 can you upload that profile via google drive or mega file sharing etc and link it here? I'm compiling a list of profiles for DRAM Calc for a spreadsheet. I have most decent kits (3600C15, 3600C16 G. Skill, Patriot Viper). The only one I need now is the Ripped.
Step 2: DRAM Calc - https://www.techpowerup.com/download/ryzen-dram-calculator/
Set memory type to Samsung B-Die
Memory Rank to 1
Frequency 3600
DIMM modules 2
Now click Import XMP and choose the file from step 1 then press the Safe button.
You should now see something like this: https://i.imgur.com/pO1tXYF.png
Step 3: Input the values into BIOS
Step 4: ????????
Step 5: PROFIT!
Thanks for that. I was able to confirm a lot of things.
Did you sort your FPS?
@Slinky69
Memory Rank to 1
Frequency 3600
DIMM modules 2
Step 4: ????????
Step 5: PROFIT!
Just wanted to say thanks again, I followed these steps and gained 3% in my Superposition 1440p score. I consider that enough to tick the "memory overclocking" box for now, I may move on and see what I can do with the CPU![]()
Just curious did you keep the 1.45 voltage or go down to 1.35 as it stated? I was thinking to myself that the safe settings at 1.35v was asking a lot.
If you want to tinker further you can press the Fast button. You will notice that tRFC goes down by a lot as does tWR. You should be able to use every setting here besides Geardown mode being disabled. This is very hard to do and isn't necessarily a RAM problem.
It wouldn't boot at 1.35, the Motherboard said "no" - I went to the "Max" setting of 1.4 and that seemed okay.
I may try the Fast settings when I have a bit of spare time.
Nice guide, thanks for sharing.@Slinky69
Memory Rank to 1
Frequency 3600
DIMM modules 2
Step 4: ????????
Step 5: PROFIT!
https://www.teamgroupinc.com/en/product/dark-pro-8packHow tall are these as I have a Noctua NH-U14 S HSF and dont really want the RAM inside the fan! (or covering it)
Team Group RIPPED Edition 16GB (2x8GB) DDR4 PC4-28800C14 3600MHz Dual Channel Kit - Black/
CAS 14-15-15-35 Timings 1.40-1.50v VDIMM Samsung B-Die
https://www.overclockers.co.uk/team...3600mhz-dual-channel-kit-black-my-001-8p.html
With a 1.5mm Allen Key you can take the black section off the top, which reduces the height significantly. I had to do so to get my Arctic Liquid Freezer II in above the RAM.
