5900x or 5800x for gaming?
Rom
Rom
28 Sep 2008
Bristol
As a amd novice, can we compare the 3800 vs the 3900 for an idea of the 5800 vs 5900 ? Are they essentially the older versions, same core and threads etc?
So if a 3800 was better than a 3900 for gaming for example, it may be the case for 5800
Ive just skipped through some benchmark videos, and the 3800 / 3900 / 3950 seem virtually identical in games. A few fps here and there, but nothing more?
13 Oct 2008
Not quite, because the 5800X will have a new feature of having all it's cores on a single CCX (unlike the 5900X) which will reduce latency. We'll need to onsee benchmarks and it may vary by use case.
Rom
Rom
28 Sep 2008
Bristol
This is all very confusing :)
Watched some 'simulated' videos, where they ran a 2 cores on each CCX, vs 4 cores on 1 CCX. Was minimal, few fps at most mainly. Though obviously doesnt mean will be the same for next gen.
15 Mar 2010
Bucks
Honestly you just have to wait on this one. Either way I cant see the 3600 losing any steam with the casual gamers due to the price/performance ratio EVEN if these news chips had higher gains.
AMD have kind of created a PR issue with these news chips as you like you say the tendency will be to focus on Number of cores/price ratio. I don't think people are going to be happy if they have to pay more , for less cores unless the performance improvements are well over 15/20%. PC gamers are (rightly) concerned about the next gen requirements and that we are (very likely) going to see an increase in games that will simply use more cores to run effectively.
15 Oct 2019
Uk
You provide good logic, however, I'm sure the head of marketing at AMD thinks pushing the more expensive part during a keynote is the best logic!
Then why not push the 5950X. I mean they did show a few gaming benchmarks with the 5950X but it was slightly behind the 5900X which they called the fastest gaming CPU.
22 Feb 2019
Guernsey
The only question I pose to myself is what do I need for a PC purely used for gaming.
And I really cannot see any use case where a 6c/12t or 8c/16t processor will not be sufficient.
I just think 12 and 16 core is overkill unless you are doing something else other than gaming.
15 Oct 2019
Uk
I'm sure the people buying the 7600K in 2017 thought the same.
13 Oct 2008
Compare the 3100 vs the 3300X to see the difference a unified CCX can make.
Benches will tell us more, but it's potentially a solid factor.
22 Nov 2018
If the 5900X has a 6+6 CCX config, then the 5800X will be faster when 8 cores are needed.
If the 5900X has a 8+4 CCX config, then the 5900X will always be faster in everything.
I'm thinking it will be the latter.
11 Dec 2016
Oxford
There hasn't been asymmetric CCX cpu ever. Don't think 8+4 is even technically possible. And windows scheduler would make a mess of it anyway
5600X > 5800X > 5900X for a gaming machine
OP
26 Nov 2017
Canada
I like 8+4 CCX config idea, however I'm 99.99% certain it will be 6+6 CCX config. Look at some info leaked by geekbench tests. For both 5950x and 5900x it shows 2 x 32mb L3 cache pools. Also symmetric design simplifies manufacturing process.
OP
26 Nov 2017
Canada
Well if it's 6+6 then that would explain why it's only £100 more for 50% more cores.
or you pay premium for 5800x for having a single CCX. I wish AMD (very smart on their end) would release 5700x (65w 8core). I'm still undecided between buying two 5800x or 5900x for my kids builds. They might be doing some streaming in the background. Also I'm not planning on upgrading their PCs for 4-5yrs. However if price difference will be indeed $100USD, perhaps grabbing 5900x makes more sense. I dunno :confused:
17 Sep 2009
Informative thread, thanks (so far as anyone can know right now ahead of third party reviews.
I'm building an eerily identical system for myself currently - even down to the Lancool II - and have been flip flopping between the 5800x and 5900x as well for similar reasons.
15 Oct 2019
Uk
18:20-18:45 from the official ryzen 5000 reveal both Robert Hallock and Lisa Su states the 5900X is the best gaming processor in the world so it would look rather odd if the 5600/5800X are faster in games.
Oh crap was the 5950x lower performance I must have missed that one :(
Only like 1~2 fps so not really an issue, ashes shows a 6% boost but I'm guessing it scales better with the extra cores and maybe the same for total war.
11 Dec 2016
Oxford
Didn't say faster, but better. As currently 3600X is within 3% from 3950X in games, at third of price, similarly performance for 5600X should be very close, at much lower price
And 5800X might end up on top in some games despite lower clocks
