Ah ok, thanks buddyIf you right-click an image open it in a new tab, you can see where it's hosted. Looks like most people are using imgur.
Thanks mate, just off to work. Will have a look laterI found Postimage to be easy to use.
Well, the weather has stopped me from working today. Back home in the warm....Could be worse! Lol.No problem buddy. Have good day at the grind, look forward to the pics.
Scrap that. Image didn't work, so I'm doing something wrong!
What idle temperatures is everyone hitting with the 3080 FE?
Mines is circa 50 degrees at 30% fan speed which is a little bit higher than I expected.
For the cpu, should I go 3700x or wait for the 5600x?
Yeah, any idea when they are lifting the embargo? It's paining me so much just looking at the 3080. Not long to wait now though I suppose...The 6 week wait to get the card is over at least.Wait for the 5600x reviews, it’s highly likely to be the better bet for gaming.
No-one knows as yet, hardware unboxed mentioned they had cpu reviews coming up this week, so helpfully the reviews will come out before the release of the chips.Yeah, any idea when they are lifting the embargo? It's paining me so much just looking at the 3080. Not long to wait now though I suppose...The 6 week wait to get the card is over at least.
screenshot timing, its 210 idle 17w power avg, 0/7 volt..
50 at idle seems high... 30% fan speed, is that a custom curve?
I run on balanced power settings, not had issues with it clocking up fully when required, although some may have and use max performance power setting.
0mhz is a liescreenshot timing, its 210 idle 17w power avg, 0/7 volt..
Sure hope so. A little earlier than Nvidia's reviews came out with any luck. With the talk of lockdown, I thought a better get my order in for all my components which are coming tomorrow. Just the CPU needed now, so I can relax a bit. Lockdown from Thursday though, so hopefully that's not going to cause problems.No-one knows as yet, hardware unboxed mentioned they had cpu reviews coming up this week, so helpfully the reviews will come out before the release of the chips.
Shouldn't do OCUK and other online retailers were open during the last lockdown.Sure hope so. A little earlier than Nvidia's reviews came out with any luck. With the talk of lockdown, I thought a better get my order in for all my components which are coming tomorrow. Just the CPU needed now, so I can relax a bit. Lockdown from Thursday though, so hopefully that's not going to cause problems.
Yeah, I didnt think it would be a issue, but the thought of sitting on the 3080 FE without a PC for it go in for a month got me worriedShouldn't do OCUK and other online retailers were open during the last lockdown.
