- 3 Oct 2020
I've had this monitor for a couple of weeks and here are my thoughts:
Hope this helps someone to decide whether to buy or not.
- It's definitely entry-level, so keep your expectations in check
- Colour contrast/calibration is a little odd. I can't quite put my finger on it, but my old Dell monitor colour space looked 'nicer'. Seems like it's always either bit washed out or over-saturated. I can't quite hit the sweet spot. (That's what she said.) I'll keep playing with the settings
- HDR is barely present. Don't expect to be awed by deep, brooding darks, or blinding highlights
- Monitor height adjustment is of limited range. I could do with it going a little bit higher in my setup
- There is no swivel - this might be normal for ultrawides (i.e. more likely to become unbalanced due to the screen width/weight)
- The monitor stand footprint is rather larger than I was expecting. Looks a bit unwieldy and takes up a lot of desk space - wall mount recommended
- Bezels are quite small. Looks rather nice. I've seen smaller, but this is fine
- The plastic case/chassis looks and feels cheap. Not the most consistent finish or of the highest quality. The Gigabyte logo at the bottom is pretty ugly, too
- The claimed 1ms response rate is being pretty damn generous. There be ghosts, be under no illusion
- I have some borderline unacceptable backlight bleed at the top left of the screen. It's only really noticeable in dark conditions and on fairly solid, dark colours. It is occasionally noticeable when gaming, but it is very noticeable when watching a 16:9 film as the solid black vertical border stands out a mile
- Flickering is more a function of the machine/use case than the monitor, I've found. I was able extend the sync range using CRU https://www.monitortests.com/forum/Thread-Custom-Resolution-Utility-CRU. I'm running a 1650 at the moment whilst waiting for my RTX 3080 to arrive. I expect most of the issues to go away at higher fps (wishful thinking?)
- My control joystick stopped working this morning, which is how I found this thread in the first place. I actually started a return request, but just now in frustration I gave the joystick a proper push (much harder than you would during normal operation) and it has started working again. Something is sticky back there. The microswitches are clearly still functioning but not always registering. Were I to guess, I'd suggest that a switch got stuck to on rather than stopped responding. I dunno
- The audio is absolute *****, but then nobody actually uses monitor speakers, do they?
- No USB hub or port is very surprising to me. It's a little frustrating as I now need to plug my low-value peripherals in elsewhere, taking up space. I mean fitbit dongle, that sort of thing.
- And how will firmware ever be updated without a USB port? Is Gigabyte hoping never to have to update this thing? I assume you can't send an update data signal over display port?
- No dead pixels that I can see. They're probably there somewhere, but I haven't spotted them yet
- It looks absolutely lovely in games. Super-fast-paces games: definitely some ghosting. I tested with Unreal Tournament GOTY 1999 (don't laugh) as I can get like 300fps on that. It has crisp visuals and no software effects that might make things look softer. It's proper rapid and looks good to my eye, but there is definitely unwanted motion blur. It's fine for me, but is you're a twitch gamer: look elsewhere. I mainly play car and flight simulators and adventure games. Not online competitive stuff
- It doesn't have G-Sync, nor is it officially G-Sync Compatible. It was advertised as such both by Overclockers and by Gigabyte themselves when I bought mine, but this has since been redacted. You can still make it work in synchronous mode with Nvidia cards, but it's on the very bottom verge of the spec.
- If this monitor were around £300 I'd call it an absolute steal. At £400, think a little harder. It's good, don't get me wrong, but it's not RTX3080 good. If money is tight then there's little to fault here, but you will get far superior results with a better brand, higher spec (and much more expensive) option
Comprehensive list thank you. I will be using mine purely for gaming purposes.
