Mine still hasn't updated, deleted app and downloaded fresh from app store still gets old oneThe new Playstation mobile app is pretty good. Much slicker than the old one!
Same for me, app store still shows the old version - Huawei phone if it makes a difference.Mine still hasn't updated, deleted app and downloaded fresh from app store still gets old one
Cheers, I'm on Google pixel.Same for me, app store still shows the old version - Huawei phone if it makes a difference.
I ended up manually installing it, there's a link to the APK in this article https://www.androidpolice.com/2020/...p-with-a-new-look-and-exclusive-ps5-features/
Someone else's quote but looks like it:
Non-essential retail can remain open for delivery to customers and click-and-collect.
Ultimately the shops could just decide to furlough their staff as they'll get more monies this way. So even though they can offer the service, they may just shut.
.....but that is finding the single point snap or breaking apex - Wear and tear doesn't work like that. Take a spoon and bend it and it won't snap........but bend it back and forth 10 times with the same force and it will.No but then winches are made to take 1000kg loads. No-one's finger can make that much pressure
Plastic is fine too, see the videos of people making stuff out of lego worm drives.
3.1kg force on 1:1 ratio, and 13kg on a plastic 24:1 gear. If your index finger alone can generate 13kg of pinch force, then go you!
The point I'm trying to make is that this is exactly what a worm drive is designed for, to be able to take high torque loads.
Yes, if you were an idiot and put your bodyweight into the trigger when it was locked out, you'd probably strip something (or more than likely trigger a release for the motor to turn off). But that's like saying the controller can't take being run over by a car - both things outside it's intended use.![]()
Seems Sony is throwing its weight around again. https://www.eurogamer.net/articles/...cancel-orders-following-a-complaint-from-sony
That means no third-party faceplates are allowed since they own the design patent.
I'm a lot more intrigued by PS5 than I was. Dual Sense sounds excellent. Miles Morales is looking amazing. And the PS+ collection, Bugsnax and Destruction All-Stars give aways have improved the value proposition. Still not sure I can justify the £560 spend though (£450 console + the Spider Man UE + PS+).
What a shame
It doesn't even necessarily mean Sony will be releasing their own, I guess. Only that they want to retain the opportunity to do so, without competition.
I had a look through the gamepass library and I swear there was only 2 games that interested me...I'm a lot more intrigued by PS5 than I was. Dual Sense sounds excellent. Miles Morales is looking amazing. And the PS+ collection, Bugsnax and Destruction All-Stars give aways have improved the value proposition. Still not sure I can justify the £560 spend though (£450 console + the Spider Man UE + PS+).
What a shame
I think my PS4 knows it's getting replaced soon, had 5 instances over the last two days where the cd keeps randomly ejecting mid game.
Original PS4, laid flat by any chance? I had this issue a while back - someone told me it's because the eject button picks up on heat from the surface it's laid on, and triggers the eject. Try raising it very slightly - I used 2x2p pieces at each corner and it hasn't happened since.
I think that’s just Australia atm.Press Start, advised Amazon have sent emails to people warning there pre order may not arrive this year due to Sony not giving them amount of stock promised
I've not had anything from Amazon myself yet
I think I mentioned this before but as an added FYI, if you're selling/resetting your PS4 ahead of getting a PS5 and aren't planning to copy games/data over from your PS4, make absolutely sure your game saves are uploaded to the online storage first. It will usually do this automatically but only if that game is installed, so if you complete a game then immediately delete it, that completed save won't be uploaded. It's worth checking as I had a few games with saves that were out of sync.
They really need to make PlayStation cloud saves free, like Xbox.No idea what region it was for press start didn't say, just thought I'd share it incase any one here is impactedYou sure this is UK?
I know US sent a blanket email to everyone saying they may not get the console on launch - basically an arse-covering exercise.
Australia apparently also sent out emails over the weekend informing some customers may have to wait.
Not heard of any UK customers receiving any delay emails yet.
Looks like it's just for Australia, thankfully.No idea what region it was for press start didn't say, just thought I'd share it incase any one here is impacted
