Yeah, I think they advice doing it without other components in, so a better do that first to be safe.A couple of weeks ago now. I flashed it just to be sure. Just plugged the PSU in on a table.
Nice, when did you buy your Tomahawk? Mine has just arrived, so I don't know if the bios has already been updated for the 5000 series.
Guess I'll have to flash the bios without knowing before putting everything together.
Do they? I don't think it says anything like that in the manual?Yeah, I think they advice doing it without other components in, so a better do that first to be safe.
Updating BIOS with Flash BIOS Button
Before updating:
Please download the latest BIOS file that matches your motherboard model from MSI® website and rename the BIOS file to MSI.ROM. And then, save the MSI.ROM file to the root of USB flash drive.
Important
Only the FAT32 format USB flash drive supports updating BIOS by Flash BIOS Button.
1. Connect power supply to CPU_PWR1 and ATX_PWR1. (No other components are necessary but power supply.)
2. Plug the USB flash drive that contains the MSI.ROM file into the Flash BIOS Port on rear I/O panel.
3. Press the Flash BIOS Button to flash BIOS, and the button LED starts flashing.
4. After the flashing BIOS process is 100% completed, the LED would be off simultaneously.
I think it's recommended to do it with just the mobo and PSU, but I don't think it's a problem either way.Do they? I don't think it says anything like that in the manual?
What has Intel got to do with it, we're talking about Ryzen. Honestly, I could understand this fanboi pish if the average poster was 12 years old.
Utter cringe.
It's not a recommendation to not have anything else connected, just not necessary.It does in the Unify BIOS, page 57, step 1
Nice set of components, what cpu are you going for?Hoping I manage to grab one on the 5th!
Already picked up:
Lian Li Lancool II Mesh
MSI x570 Tomahawk
32GB Crucial Ballistix 4000hz (2x16)
Palit Gaming Pro 3080
NZXT Kraken X63
Superflower Leadex Titanium 850W
Sabrent Rocket PCIE4 2TB
Noctua Chromax fans
After speaking to the competition it looks like the numbers for release day are really really low, so I'm going to assume OCUK are going to be worse if the Ampere launch is to go by. I wouldn't expect to get one on launch day! There is a european retailer that has only 13 5950X which is similar to what I heard from the UK competitor. I'd expect price gouging across the board with these numbers.
Yeah, not at all.not what i wanted to hear![]()
Again CPU's can be ordered 5pm on 5th November, we also expect to have product on the shelf and I have ordered thousands of CPU's so if our demand is met then supply for OcUK customers should not be an issue.
