- 24 Jun 2003
Thanks for the info , yip if i change my ram i think i would get the 3600mhz 8 pack memory and downclock itYou mean RAM which comes with a speed of 3466 CL14? No, can't find any. You can go look for some G.Skill FlareX 3200 CL14 and oc it to 3466 CL14, which is fairly easy to do with the 2700X. Or, you can get this . . .
https://www.overclockers.co.uk/team...3600mhz-dual-channel-kit-black-my-08q-tg.html
either try to run it at manufacturer's spec using DOCP or the DRAM Calculator. But, you might be able to run it down to 3466 CL14, again using the Calculator and compare which between settings gives the lowest Memory Latency using Aida64.
Sometimes it is easier to downclock than to oc and still get better memory latency. You want to shoot for at least 65ns. A 3466 CL14 on Gen 1+ will give you about 60 ns.
That RAM kit is perfect for Gen 2 and might work just as well with Gen 3.
Is CL short for Cas Latency ??
