B350 doesn't support the 5xxx series at all. Only the latest 550 and 570 do at launch, plus support for 450/470 will arrive early next yearHey guys, upgrading from a 1800x on a b350 tomohawk, would i need to upgrade the mobo for the 5600x?
Ha !Wish granted. Reviews will be 1h after launch.![]()
I suspect an overclocked 5800X will be the best choice for games due to having only a single CCX and not having the penalty of crossing the infinity fabric.
As to how the 5950X will perform - probably very very well, except that having that many cores in one package it will run into thermal limits more easily. It's hard to say how much of a limiting factor this will be, if at all.
if i was looking to purchase a mobo out of the box to work with the 3070 i've got ordered what would be best?B350 doesn't support the 5xxx series at all. Only the latest 550 and 570 do at launch, plus support for 450/470 will arrive early next year
haha ikr. forgot I registered awhile ago lolwow, first post in 9 years Welcome to the madhouse lol
Any B550 or X570 boards. MSI Tomahawk's or Aorus Pro's of either chipset are the go to selections.if i was looking to purchase a mobo out of the box to work with the 3070 i've got ordered what would be best?
No performance difference, but the 4 series boards are having to wait longer for compatibility with the 5000 cpu's. Most are saying Jan for the BIOS update.stated that there is no performance difference between the 2 types of boards.
Fair play for managing to remember your login details Lol.haha ikr. forgot I registered awhile ago lol
@Temujin Where is it advised to get a 5 series motherboard i have a b450 aorus elite obviously 5 series are better but amd have stated that there is no performance difference between the 2 types of boards. I agree with upgrade on the b350 tho.
I suspect an overclocked 5800X will be the best choice for games due to having only a single CCX and not having the penalty of crossing the infinity fabric. The 5900X will absolutely rule in multithreading and when compared at stock it might be faster in some scenarios due to being clocked higher. But if you're willing to overclock a bit and *only* care about games, then 5800X is probably the better choice. I do a decent amount of video encoding so I'm aiming for 5900X, but I'm not sure if that's the best choice if you only look for a gaming CPU.
Yes, and the windows scheduler will be aware of it. The problem is that games aren't aware of the architecture, and there's plenty of games which spawn 40+ threads on Windows, so the scheduler will just assign them wherever(they all belong to the same process, and there is more of them than there is cores, so they will just go wherever is free first), so in some cases you will be running into that penalty. Consoles in theory have the same problem, but on consoles you usually assign the core affinity manually by hand, so games get really optimized to avoid that problem.
As to how the 5850X will perform - probably very very well, except that having that many cores in one package it will run into thermal limits more easily. It's hard to say how much of a limiting factor this will be, if at all.
Glad to hear there will actually be stock and that the 5800x seemingly has the least views and possibly the least demand as that's the one I want.
This could not have come at a much better time for me though as yesterday my 4790k finally gave up the ghost after having to underclock it for the last 2 years to keep my PC stable. So I'm without a PC and using my crap work laptop today and and tomorrow, I'll hopefully have me shiny new Zen 3 PC built in time for work on Monday morning.
Interesting. I guess the same is possible on a 5900X? Disable one CCX if this is possible in software / BIOS to only use 1 CCX with 6 cores. If games only require 6 cores or less then surely having both CCX and 12 cores will increase latency.Seems one (expensive) solution is to turn off one ccx on a 5950X lol, that way you can use the higher binned ccx with better thermals compared to the poorly binned 5800X.
One thing I don't have knowledge of, are the CCX packages all 8 core? e.g. the 5600x is 8 core with 2 worst performing ones disabled?I think the 5600x and 5900x will be the most popular and best value, especially if performance is relatively close. Probably works in favour of the 5800x as the stock levels for it will likely be worse than the others as it needs a complete CCX.
Yes.One thing I don't have knowledge of, are the CCX packages all 8 core? e.g. the 5600x is 8 core with 2 worst performing ones disabled?
hoping to go x570 due to the smaller upgrades for longer life span etc
