Cpu is still at stock but yeah ipc is king on heaven when it comes to cpu ive not finalised any clocks yet just done quick dirty oc on the gpu and yes its a 3090 fe. I'm really impressed with the cooler though Idle 30 and max is 52 so far I've seen
i could be hurting performance a bit then with a all core 4.7ghz, my chip at stock would boost just over 5ghz but would quickly drop back, that extra 300mhz could very well boost me more, but given the all core dropped back to 4ghz out of the box it may hurt the score even more
I defiantly didn't win the lottery on memory with this card as i have seen other go quite a bit higher , core seems spot on but memory no so good .. Got a water block arriving on 20th November so hoping and praying that helps it out a bit but what the card really needs is a dual sided water block of some sort as yes you can pretty much cook a steak on the back plate at its current temperature
