Hey! The Swift's are a good little car, I know as I work at a Suzuki dealer
theone8181
The trouble is the wear removes all or part of the protective soft (babbitt) layer of the shell, this then leaves the bearing vulnerable to scoring and galling when dirt particles get in there, or when the engine is started or stopped. Additionally the wear isn't even, so the shape of the 'hole' is no longer right and this negatively affects the hydrodynamic oil film that's meant to keep bearings and crank apart (not something you want to risk on an 8000+ RPM engine costing ~£7-8k + labour for a 2nd hand engine). You can read about bearings in the pdfs I linked in my massive post on the previous page (at the end of it).
You could argue that a
very slight wearing wouldn't cause a problem for a very long time, but the trouble is you don't know which engines will be ok until you either strip it or it dies!
That's because people aren't pulling bearings out of engines 'just in case'. This issue is self perpetuating.
Who’s the expert ? BMW engineers or some guy who sorts bearings in his lounge and sells them as the fix ?
You're still missing the point that most shells removed are excessively worn, and all this started because an initially small number of engines were blowing up with no obvious reason about 7-9yrs ago or so, the more people looked the more people found there was a problem (with most engines, but not all).
If you are referring to BE bearings as being 'some guy who sorts bearings in his lounge' then you are massively mistaken, they are a company who rebuild all sorts of engines and have done for many years, and at least part of their workshop is more like a machining shop, they have an extensive array of tools to carry out very high precision measurements of various engine parts. If you weren't talking about BE then ignore that line
Robbo
A very nice car you've bought
Jonnycoupe
Not sure what you were getting at with that post, but anyone who has it done will be glad it's done as they now
know they don't have dodgy/overtight* bearings regardless of how good or bad their old bearings came out.
*assuming they don't use OEM bearings, lol.
