Caporegime
- 21 Jun 2006
AFAIK they're supposed to last like 6 months.
All these options have a cost associated with them: regain you have to buy and use regularly, finasteride is only available on a private prescription. The other poster highlgihted that wigs aren't a replacement for real hair... if he meant in the sense that there are compromises then that applies to other solutions too - hair transplants won't be as thick (that isn't to say they can't provide sufficient coverage of baldness), regain might not be completely effective ditto to finasteride (might also have side effects - note the OP mentions he tried this but then stopped because of side effects).
Some people fly to Turkey and get the operation done at a lower cost (as per OP), there are different procedures (FUE vs FUT) and you might well require multiple procedures depending on how much coverage and thickness you want... in the UK if you want it done comprehensively at some of the top places then it can run into tens of thousands of pounds (as per Rooney).
In some cases it might not work out - some methods that work for some people won't work for others - OP mentions trying other (medical) solutions, those might be things others swear by. Likewise some people probably love their hair transplant, others might have one that didn't work out.
So tell me how they last 6 months when there is real hair growing underneath?
It's 2-3 weeks max. Think how often you shave your beard that hair growth is happening underneath.
