I’m pretty sure at this point g-sync and freesync are interchangeable?
nVidia cards can use both freesync and g-sync but AMD cards can only use freesync.
So if you have a g-sync monitor you need an nVidia card to use that feature.
Good morning,
I've just received the iiyama yesterday. No dead pixels, firmware seems to be the new one and I'm really happy with it.
However next to an older 144hz full hd ips panel the iiyama seems a bit yellow-y, does anyone know where I can find a good profile for it? Or perhaps a nice setting?
Cheers![]()
Just got mine today. Gutted looks like it's the new firmware, but I def get a flicker at 144 over display port, and an audible sound with the flicker too. Has anyone tried after market display port cables to see if it sorts the issue? Are people with the issue all using the cable that came with the monitor? The only reason I ask is there's a vid in YouTube re a similar monitor but an lg version where a guy suggests it's the DP cable that came with the monitor that is trash.
See my previous post — a new DP cable sorted mine
Ahh ok, just gone back to look. Do you have a link to the cable you bought? I notice you say it was about £10, but the ones i can find by the brand you mention are more than double that.
I have a swap service coming tomorrow but this seems like a decent monitor no dead pixels, i really dont want to end up with a lower standard replacement if all it is is the cable :/
Many thanks
Its a lovely screen other than the issues.Good morning,
Cheers![]()
What you describe is exactly what I had... so I expect it’s the cable.
I don’t think I’m allowed to link to competitors?
If you find one of their cables - look at the product page and change the “size” - they do VESA and normal ones. Mine is a non-VESA one. I don’t really know what the difference is but it works fine.
New DP cable arrived today, not the same one you mentioned, but one that states 8k etc etc...
I think its fixed it, no clicks flicks or pops so far after it being plugged in for 15 mins ish
You sir are a legend! many many many thanks![]()
yeah i got a bit suspicious after finding mine already had the new firmware on it. :/Excellent!
Saves the faff of sending it back etc
(was in the same position — called up Iiyama support and they told me it needed new firmware — checked and it didn't, so got suspicious of the cable)
I thought that min had the new firmware but repairtech still took mine in after i was getting the 144 flicker and noise. Whatever they did has fixed the issue and its now a stable 144hz image on my 2070.
I was getting black screens for a few seconds if i have G-sync on though... Doesnt matter as ill be onto a 6800xt/6900 next year so hopefully itll play nicer with freesync then.
Interesting - I might give them a call next week to ask.
