Woah!No, I was trying to install the heatsink on it!
I am guessing he forget to pull the lever down to lock the cpu and through brute force the cpu came off the socket.Confused how you manage to bend pins installing the heat sink on it?
Interesting. Have you got another cpu to test the board with? That kind of force would have caused damaged to the socket.No, it was locked in
I was installing the wrath cooler and it needed slight re-adjustment and when I pulled it back, the pre-installed thermal paste/grease on the bottom of the wrath heatsink was like glue and yanked the CPU out.
The locking pin on the motherboard is still down even though the CPU came out
Yeah you should always wiggle/twist the CPU cooler
^^ trust Vince - he rides CPU's every day to work. It's his main transport.
To the people suggesting RMA, he physically damaged the product, there is no warranty for that.
Also there's the potential for it still not working even after you've straightened them.
