4th January ETA... ******* hell. Let's hope EK get a distro plate out by then
Just looked at the dimensions, 43 litres volume! Same width as the full sized PC11 despite using an SFX psu. It's massive!
Laughing at some of the notes on the Lian Li site:
"Think big, build small"
"Adequate airflow"
Still, it's a good looking case at a nice price. I just hope Lian Li decide to actually build a small version!
Indeed. Go back to the original concept where it was 280mm radiators top and bottom, with a 240mm on the side (iirc? might have also been 280). Support mITX (and mATX motherboards without a bottom rad) only to stop the depth having to get too big, these boards should come right up to the positioning of the side radiator rather than having ~10cm of space for giant cable runs. Keep it fairly narrow, it doesn't need a 120mm fan on the back - just have the main compartment wide enough for a graphics card with waterblock terminals on the end!Here's hoping they follow it up with a proper ITX version, rather than this half baked mess.
I'd buy one in a heartbeat!
What size is it? I'll take a look on the drawings for you to see if it will work.I’m going to try and fit an atx psu in one seeing I bought a new platinum 850w earlier in the year to replace the 600w sfx one I was using before.
My idea at the minute is to either see if it will fit on the bottom at the front underneath the vertical gpu bracket and make a shroud to hide the cables, or try and get it where the bottom side mounted fan goes.
Plan B would be make a new side panel with a power bulge, or going to extremes, see if I can relocate the motherboard tray.
This feels like the sort of rig this case was built for. Absolutely stunning, and puts the extensive water cooling compatibility to good use.
