Saw these comments on hukd, anyone agree?
1: The case is a mini oven. I have gone on reddit and customised the hell out of the case and still cooks up all the hardware.
For Reference: My specs are AMD 3900x, rog strix X570, 2 x 1tb M.2 Drives, GTX 1080, 32gb Memory
2: The pump makes a weird whining sound it's not just mine a lot of people online complaining about this noise, it's very common.
3: Front glass panel is useless should have been another vented panel for a better airflow.
Thanks for the reply. What are your CPU and GPU temps with and without the glass please?
Really wanted this case, but I don't think it would cope as a gaming pc to play 4k gaming. If they release a new version with 750w/850w and better ways to reduce thermals, I'll be all over it.
I just picked up this case second hand but with a custom wooden front panel. I'm also gonna replace the AIO fan with a Noctua and also stick 3 x 40mm noctua fans in the back to rear exhaust. It really is a lovely looking case and I'm willing to make some adjustments/mods to make it work
Specs are : 9600k, EVGA Black RTX3070.
I'm currently using a Dan Case A4 with black ridge cooler. The GPU is literally 2mm too wide so the side panel wont close correctly. I've had my eye on the H1 for a while and when I found it second hand including custom panel, I snapped it up. I'll be moving everything over on Wed when the 40mm fans arrive
Happy to run any tests etc.
Anyone have a link for a vented front panel in stock, in the UK?
