Ah maybe tomorrow thenI didn't either
He actually has came in a few times, pretty sure his last update was last week. He's not silent you just don't read every postYeh they got till next wkend for me, im still 127 in the queue, its ridiculous that Asus said they would raise numbers yet numbers are actually down. Where is the support guy who pops in once in a blue moon, why is he silent after he took time off
Bloody disgrace if you ask me, what a way to treat your customers and so much money aswell.
Afterburner, been fine, just make sure in nvidia control panel you set power mode to max performance so the clocks down drop down.
Nevermind. Think they have gone now. Delivery no longer available. Not that I was interested anyway. Just thought some of you may have been.TUF Gaming Oc available elsewhere...
I tried too...wasn't quick enough in the 10 milliseconds between the stock alert and clicking the order buttonNevermind. Think they have gone now. Delivery no longer available. Not that I was interested anyway. Just thought some of you may have been.
Done the same as you.
10,000 memory and 2100 on the gpu.
I have hot the power limit, if I want to go further I will need to flash a 390W bios.
Thanks for your help![]()
What temp do you get at that power limit? id have to run 100% fan to maintain reasonably temps at 123% power limit on the card, but way too loud.
@350W it's about 55C
I have my fans full on over 50c
With the fans on normal it would throttle back.
Waiting for Alphacool to do a AIO for this card.
Ah yer, I remember you saying sorry!
Any chance you can test without the fans on full but stock at that instead? Just curious to see what peoples cards temps are getting too @ stock fan. No worries if not (good test if Port Royal or Read Dead 2 - as they seem to really max out the power on the card)
It goes to about 70c+ then throttles back.
I never tried again..
The first time my deafness has helped![]()
Seems on par with mine then, will happily reach 76deg at 85% fan then throttle back below 1900mhz. Cheers
I won't let it get that hot.
Touch the back after....it's very hot...
with 50-70% fan.Same, was only testing to see what card does at max power on stock fan, my undervolt keeps it 55-65deg maxwith 50-70% fan.
I found a YouTuber called Frame Chasers, he has been documenting some insane 3090 mods to power and cooling his card to be fair looks amazing and pulling 800w max under water using shunt mods for daily gaming not suicide btw.Is that with the overclock?
I will leave mine as it will go under water soon.
Then I will flash a better bios. What card you got?
Do anyone know rog strix 3090 oc?
Two weeks in a row I've been ranked 74
I read on another post that are all TUF for this week
Other site is showing there ASUS deliver this week is delayed until the 6th December! This is getting stupid now!Yeh no news this week it seems, im 127 and getting extremely upset and down about the lack of movement
