- 25 Nov 2020
https://photos.app.goo.gl/TVwYsZTrz48CQLRz9
The screws you can see on the left are the screws for the fan, running through existing holes in the chassis. The right side doesn't line up with existing holes, and I didn't want to drill in to the chassis. So I used cable ties through the fan grille and existing chassis holes.
The mains cable now sits next to the top 120mm fan. While this works with the SX500-LG, other PSUs might need a different solution, as it'll depend where the power cable exists the top of the PSU.
Awesome, thanks man. I might give this a try if my case ever turns up!
On the subject, has anyone heard from Overclockers regarding stocks in the last week? I had a response but it was the same vague answer of "soon".
They're pulling a lot of current into a very concentrated area so temperatures spike very quickly and even high-end cooling won't have them running at really low temperatures from what I've seen so far. I'd not stress about it unless you aren't hitting the claimed boost targets.
