Should be good also when RTX IO kicks in, all this 'free' performance benefits!![]()
RTX IO LOL. That's probably vaporware. I don't see why everyone wouldn't just use what will be the windows native feature called Direct Storage
That is my understanding yes.Isn’t RTX IO just their implementation of direct storage?
Oops, looks like it's just the plugin. Implementation sort of implies something more complex but Nvidia's own description says its just a plug in that allows the GPU to use Direct Storage - so basically just a driver API
Nvidia branding it as an excuse to later block non ampere cards from getting it in a new driver? Otherwise I don't understand why Nvidia needs to brand it "RTX IO", just saying their support Direct Storage would make more sense.
Like they took Freesync and branded it to G-Sync compatible after losing that battleThink of it like DLSS just erm, yeah. Typical nvidia branding of a standard that shouldn't need proprietary marketing... but I suppose you gotta sell them cards right!
Like they took Freesync and branded it to G-Sync compatible after losing that battle![]()
It won’t be long before nvidia tries to rebrand SAM to something something RTX. Asking mb manufactures to provide a bios update to rename it in the bios.
Lol
Good one. I think they might use:$5 says they call it "Nvidia Super Smart Access Memory" NSSAM
I wouldn’t hold your breath.surely AMD will add SAM to Ryzen 3000 now
You know what he meant. Nvidia went on and on about the tech requiring their module (and little fan) for 'quality' adaptive sync and tried to push the premium as a guarantee of quality of the monitor. As soon as Freesync monitors were dominating the marketplace in choice and equalling it in quality for less, they announced the module-less 'gsync compatible' branding to smother the freesync brand. They successfully re-branded monitors that had been labelled as freesync as 'Gsync compatible'.Technically it doesn't work like that.
https://www.techpowerup.com/275565/...mitation-intel-chips-since-haswell-support-it
