Why doesn't it work right? Do you even know why MCAS was implemented.One sensor, for a completely new system all because Boeing went cheap, on a plane which basically doesn't work right so the need to counter its bad dynamics.
Because unsuitable engines were incorrectly bolted on?. . . Do you even know why MCAS was implemented.
To counter the fact the bolted on engines not designed for it in the first place as Boeing went super cheap and lazy on the deign.Why doesn't it work right? Do you even know why MCAS was implemented.
Where did Ryan Air find those billions of US Dollars in the middle of a global air travel slump?
It was my understanding that is needed because they used larger bladed engines so needed to mount then further forward which altered the handling characteristics and to keep the plane handling like previous generations MCAS was used.Because unsuitable engines were incorrectly bolted on?
Because they redesigned on an older model plane, then went ahead with the engines to try and make them look more green then had to make the MCAS system so when flaps where down it didn't pitch the plane up ( i think up or down), they went cheap again and only had one sensor for when the system needed to kick in, and never told pilots about it being installed.It was my understanding that is needed because they used larger bladed engines so needed to mount then further forward which altered the handling characteristics and to keep the plane handling like previous generations MCAS was used.
Taken from an article here => https://www.perell.com/blog/boeing-737-maxWhy did the 737 Max crash? Because of a software failure.
Why did the software fail? Because Boeing’s executive team has lowered its engineering standards.
Why did Boeing lower its engineering standards? To lower costs and increase efficiency — the goal was to save money.
from the episodes of aircrash investigation I've watched which were probably all episodes from before the 737 max existed, it seems like most crashes are pilot error due to lack of familiarization or from not understanding the planes systems properly. (like the time some pilot let a kid at the controls, unaware if you jerked the control around in particular way it overrode the controls and the kid sent the plane in to a unrecoverable dive)
kinda crazy they would fast track pilot training to a few hours unless the cockpit and system are identical to something they are used to.
100% this. If a plane you're in ever gets into a serious malfunction you had better hope your pilots have a cool head and true understanding of it's sub-systems.
What would you do if the accelerater in your car wouldn't stop?
That's amazing.This will make you feel better:
https://www.google.com/amp/s/amp.th...19/jun/15/boeing-dreamliner-b787-safety-fears
In the manuals it literally says the fire switch might not work, we couldn't believe what we were reading.
"If it's a Boeing, I ain't a going"question is who will be first to fly on the 737 max
In any critical system, you ideally want 3 sources of data to come to a conclusion and I thought that wasn't the case here.
What if one fails and the 2 remaining disagree? Which one is correct?
I may be remembering wrong but they never approved the original max design did they? I thought one of the main issues was that because it used the same body/wings as it's predecessor it didn't technically qualify as a new plane and so recertification was not required. This was part of the cost/corner cutting Boeing did to chuck them out the door half baked before the Airbus Neo secured all the contracts.If only it wasn't by the same agency that approved the original max design....FAA has lost all respect
