It going to feel like a very very short week off work this weekAaaaaaaaarrrgzzrgh! It's going to be a long long long long long long long long long long working day today![]()
Is the performance hit with HDR on, significant? Also, does anyone else find the graphics to be a bit blurry and grainy? I'm running mainly at high, and it doesn't seem as sharp as I was expecting.
How are 1080Ti players getting on at 1440p ?
Turn off motion blur, chromatic aberration and film grain.Is the performance hit with HDR on, significant? Also, does anyone else find the graphics to be a bit blurry and grainy? I'm running mainly at high, and it doesn't seem as sharp as I was expecting.
I haven't tried it with HDR disabled yet, I test it later to see if it makes any differenceIs the performance hit with HDR on, significant? Also, does anyone else find the graphics to be a bit blurry and grainy? I'm running mainly at high, and it doesn't seem as sharp as I was expecting.
I would expect HDR would not impact performance?
Not sure what I'm going to do with WDL now, maybe uninstall it, it's like an obsolete game.
Anyone playing this on a more modest system?
I have a Vega 64 and 5820K and i'm little disappointed that on medium settings i'm only get around 40fps at 1440p.
I'm at 3440x1440 which is 20-30% more pixels and I'm getting 30 fps on average at high.
HDR is working fine
This is the HDR settings Screen
You and me both!
My GPU is vega 56 with latest drivers for what it's worth.
Other games HDR is perfectly fine.
It's not bugged me one bit tbh, i usually just adapt or change 1 key for crouch. Not had to do any for this game and im not finding it difficult to learn the new layout.To be fair the UI and button mapping in this game is appalling. I can easily imagine that it will put a lot of people off quite early in the gameplay.
https://www.pcgameshardware.de/Cybe...k-2077-Benchmarks-GPU-CPU-Raytracing-1363331/I'm guessing a 5600xt will struggle run this game?
I always leave the windows HDR setting enabled ( I see no reason to disable it)You are right. Unlike all my other games you need to enable HDR in Windows Settings, it doesn't just kick in automatically.
Enable in Windows Settings and then it works. Not sure why it doesn't kick in automatically![]()
