The only way to know is to try it and see if you like the way it looksIs it even worth turning on HDR if your monitor is only HDR 400? I've tried it before just on desktop and it looks a mess...
I'll give it a try tonight, i just remember turning it on via the OSD and it looked really washed out and contrast was way way off. I guess i'll need to calibrate it if i turn on HDRThe only way to know is to try it and see if you like the way it looks![]()
Restarted my pc by accident because I spilt coke in my k70 keyboard and now I'm using a ****** temp one that has a power button. ahhhhh
OMG, that's brutal, erm that's an F from me!
Small, a little bit bigger, a ladies front bottom. That's it.So who came up with the most outlandish genitals then? For such a hyped feature I've barely seen it mentioned?
Yeah this was a disappointment after all the talk about it i have to say. And why are only the male genitals customisable? Meh. It doesn’t affect gameplay or my opinion of the game. However it is a small thing that has been overhyped and failed to deliver, and they can add up.Small, a little bit bigger, a ladies front bottom. That's it.
Go play it and find out for yourself.
You have an unhealthy obsession with attacking the game at every opportunity, bit weird to be honest.
You get a choice of genetalia in character creation, no gender, penis 1 to 3 and vagina.
GoG is owned by CD project red, so they get a bigger slice of the pie when you buy it. The gog version also has no DRM (not sure if that is the case for the steam version).What are people preference in terms of steam v GOG. Is there any real advantage. I don't know much about GOG but I'm hearing it a lot in this thread
