- 5 Aug 2017
- Cornwall
You have a 75w allowance on the pci-e slot too.I think we need to be careful this time around as that’s a mistake some have made with their 2x8pin 3090s.
The Evga XOC bios has a hard limit of 150w per port, if you flash onto a two port card you end up with a 300w card instead of a 450w one as the bios won’t pull more than 150w per port.
That said, it depends on whether there will be an XOC bios for the 6900XT at all and which manufacturer does one.
I'd not want to be using more than 300w using water, I'd save the wattage of fans, power leakage from lower temps so in time I'll have to see how far that gets me!?
