- 31 May 2009
oops thank you
Me too.
Cyberwear, crafting, quickhacks, upgrades, the tech tree, none of that is even slightly explained, I've found myself on forums and YouTube way more often than is acceptable.
You missed the "It's a tad frustrating having to run around the corner every time to loose the cops"
My cops seem to be bred with bloodhounds! I mean the longest chase was easily over 3 minutes of sprinting (500m+) and and taking back alleys and yet I still ended up reloading the last quicksave to avoid the hassle. On the other hand I ran over a civilian by accident and had a less than 10 sec car chase, sooooo swings and roundabouts I suppose!![]()
1) Driving in 3rd person is way easier, if you've not tried this yet then the key for it is listed at the bottom right of the screen, cockpit view from the cars is god awful.
2) Save often, quicksaves rotate over 3 slots so you can use it liberally and still have multiple points in the past to jump back to, quicksaving also takes no time so it doesn't interrupt game play.
3) Never sell anything for money, you'll end up with a lot of money naturally through other means always break down items you don't need into components, you'll likely do some crafting eventually. If you do get short on cash you can always sell the components you broke the junk down into. But rare/epic components are hard to come by where as money is not.
4) Don't buy the perk to automatically break down junk, most junk items are worth $3 but some early game are worth $750 and then later on $6000 which it will scrap automatically.
5) Re-visit vendors frequently, as you level up your main level and street cred new and cool items become available you don't want to miss out on
6) Your level in any attribute can't exceed the points you've put into that attribute which leads to wasting exp, to prevent lots of wasted exp consider prioritizing attribute points towards things that are level locked
7) The crafting screen has an upgrade tab which is easy to miss, this allows upgrades of your current weapons
8) On the character screen each section can scroll, the journal section has many other sections to look at tutorials and data shards.
9) If you're low on ammo you can craft it, if you have too much ammo (there's a max limit you can carry) you can sell extra to the shops, they don't appear in any filter except for the "all" filter. Same can be said for buying ammo if you're low, a gun vendor will sell ammo but again not under any store filter other than "all".
10) For cash, access points are a good source of money, there's hacking perks to increase the amount of money you get from them which I'd suggest you invest in as early as possible. And there's a perk to also show them on the local map/radar which is also worth investing in, you want to hack every single one you run into because they're an easy ~$1500 a go.
For maximum cash hacking access points, you always want to primarily target DATAMINE_V3 as that gives the most, and optionally V2 or V1 if you can get them in the same hack. You can overlay multiple datamines in the same buffer so for example if you have the sequences
DATAMINE_V1 = 55 1C
DATAMINE_V2 = 1C E9 BD
DATAMINE_V3 = BD BD 55
And your buffer is size 4, then you can get both V3 and V1 by doing BD BD 55 1C, the rules for this are kinda not obvious at first. You can get any combination of datamines, the 3rd one isn't contingent on getting the ones before it which is a bit ambuiguous from the message on screen that says "sequence required to upload". The sequence doesn't need to start at the start of the buffer, as long as it's contained somewhere in the buffer before it's full. Buffer length can be extended with investment into the hacking attribute. The timer doesn't start until you click your first code, so plan your route first.
One last tip, these are randomly generated and there's never a guaranteed way of getting more than 1 datamine, there's some RNG to it. If you get a "bad" one, like for example you can't get datamine v3 or you can't get v3 plus at least one other, you can hit escape to leave the screen and jack back in a 2nd time to re-roll the RNG and see if it's better. You can do this infinitely but each time you do it the time remaining clock reduces. But it never reduces below 6 seconds which is long enough to execute any length sequence with a mouse. Purely out of not wasting too much time my personal preference is to try and get V3+V2 at least, you're more likely to be able to get all 3 as you invest point into the skills however, primarily having a bigger buffer is what helps the most.
11) It's not just guns that can have mods but clothes, implants and can to, you can tell because they have a little circle symbol at the top left of the item for how many mod slots it has, so not only can you get benefits from something like an eye implant you can also add mods to that eye implant. Higher levels of implant have more mod spots. Also each mod has variants (common/uncommon/rare/ etc) this is especially powerful for the Cyberdeck which is used for hacking, rare and epic variants of mods are much more powerful and should be swapped out as soon as you have improvements.
12) When doing stealth and leveling up you get points for both takedowns and for hiding bodies, so once you've cleared a mission area of all bad guys, if there's body hiding spots that aren't full you can run around and hide all the bodies for more exp. Different bins have different body limits, some hold only one, some as many as 3. The light on side can either be green/orange/red to indicate (empty, used but not full, full)
13) Many of the perks have bad math which makes them stack in a multiplicative way rather than additive, especially noticeable with guns, you can get damage output up to extreme levels if you apply the right combination of perks for a specific weapon. You can get pistol headshots up to over way over 10k dmg, plausibly several orders of magnitude more by end game. You can also stack chance to crit through the right mods to be more than 100% so you always crit, so plan your build carefully.
14) if you're going stealth/non-lethal like me, focus more on quickhacks. You want to visit ripperdocs and get upgraded variants of the cyberdeck which can hold more quickhack mods to give you lots of options to disarm/distract/disable enemies in aid of stealth. Honestly the cool tree has very little in the way of direct stealth benefits, you get way more aids to stealth through quick hacks.
15) Damage drop off for weapons over distance can be extremely aggressive, especially for pistols, if you're focusing on sneaking with 1 shot kills you may find yourself needing to get very close to enemies. There's a late game perk to disable damage drop off.
16) Use alt one tap to bring out weapon, double tap puts it away, and holding gives you a weapon wheel. NPCs may react negatively if you have a weapon out so knowing how to holster it can be handy.
Putting the question in spoiler tag, bar the name of the quest which is Monster Hunter, so if anyone done that quest you can take a peek and maybe help out ?
Can they just write the code and patch the game and make the AI suddenly more advanced and better like how I've described? Is this even possible?
