Watercooled Case Gallery
1ceHXzR
Can't say I'm all too fussed on this one
Way too much going on and clashing
Here is my latest build, which I have just updated from the Lian Li 011-XL
Few Arty ones.
My new case InWin 925
Not finished, but getting close.
Phantek 719
Alphacool monstaa 480 with push pull noctua redux 120s
EK D5 and 250mm res
EK 3090 block
EK velocity cpu block
Still figuring out lighting etc, and overclocking it... Palit 3090 doesnt overclock that well, will be replaced at some point.
The run from Pump to GPU needs tweaking, angle fittings or some such so that it sits as a nicer straight run.
Oh it's far from perfect. I get why people like it but it's not for me.
Up until recently I was using a Silverstone FT02 and now I finally have a Phanteks Enthoo Primo. If I could get the space of the Primo with the motherboard layout of the FT02 then I would be closer to perfection.
I bought an 011D in black as well because every other case has ugly exterior from what I've seen. Plus I really love the PSU compartment hidden in the back.
Not only that, once I've found you go Lian-Li you cannot go anything else.
I haven't bought my O11D XL yet because no stock until like mid january, but I just got a delivery of 10 UNI SL120 fans recently and I feel the same about them. Everything about them is stunning from build quality, aesthetic, RGB light quality (they do the most perfect white I've ever seen) and I don't ever want to use a different 120mm fan again
Got my new heatkiller block for my 5950x
Hey mate. Just noticed you have the Gigabyte Master and lots of nice RGB going on.
I just cannot get RGB to work on my master properly at all.
The Fusion software either crashes or I can only control the RAM rgb.
I basically just have to keep the colour the default red.
Not a massive issue, just thought I would see if you had any similar experiences?
You have a fairly similar rig to mine.
You may be using a hub or something also.
Thanks,
