- 6 Sep 2016
So going back to the point about the Sony receiver. If my amp "can" pull upto 750 watts, or 375/channel, but can only output 140, then what's the Sony going to do if trying to run 5 or 7 channels?
Don't forget 750w max
Into 8 ohm 140w
Into 4ohm probably 200w
Into 2 ohm probably 300w
As for that Sony, divide max power consumption by numbers of channels it has plus deduct amount for loss,and power usage for DSP, and for proper rated out not high the and into 6 ohm sin.i'd say take off 10w per channel
