The Radeon RX 6900/6950 XT Owners Thread.
Are you sure about the voltages? Radeon voltage limits are not adhered by the card. You can check in GPU-Z. Also, if performance chasing is not your concern you should reduce the TGP, it is just wasted power unless you really need it at 4k for some power hungry game.
My max voltage is manually set to 1162mv. Fans don't bother me as I am a headphone gamer so let the jet engine rip !
I monitor the voltage via HWINFO64 using an OSD so It’s accurate.
I don’t set it via MPT.
Example
Example
HWINFO64, GPU-Z same thing. Though COD is not the best game to judge max voltage or max anything but if your voltage does stay around this limit then you haven't lost the silicon lottery that badly.
Yeah it’s not the worst but pretty average compared to others. That said, I’m pleased with 2500Mhz in game and I’m easily able to maintain 100+ FPS in my most played games at 5120x1440 which is handy for fast paced shooters.
Well it came yesterday.
And its in and working tonight.
Very pleased so far. Jesus, it doesn't miss a beat.
https://~ibb.co~/Bj6JNTc
https://~ibb.co~/Bc0tz7j
https://~ibb.co~/52dvz48
Thanks. Knew this would happen.
Don't post many images on here. Just copied the url into the image icon on the toolbar.
Every time I do I run into this trouble.
Help please.
If its imgur you need to copy and paste the url that says bb code.
That or open the image on another tab so that the address will end with .jpg, then click here on image and insert that address. It only works if the web address ends with .jpg or another image extension.
Take two.
https://i.~ibb.co~/Y8dSZfP/20201231-195548.jpg
https://i.~ibb.co~/rFDm7LM/20201231-194600.jpg
https://i.~ibb.co~/7bHVTCW/20201231-194816.jpg
Excuse me.
more of the same photos by the look of it.
Trying to do this from my phone and had a couple new years drinks.
Got the old vega64LC out and the new one in before I started though..
It is fat, yes.
Junction temp up to 94c after about half hour on PUBG. Maxed out at 2560 x 1440p
Idling on the desktop now at 41c.
junction temp 47c.
Excuse me.
imgur won’t work properly from the phone. sadly.
I don’t think so mate.Mates running MPT,sub ambient and open bench effect this gen greatly.Then toss In water block with sub ambient let alone dice & ln2.
Anyhow how happy new year my favorite *******.Ready shortly to smash 3dmarks greater then before!!
3090 has nothing on 69000 below 4K.RT is useless this gen.
Happy new year mate. :)
