ASROCK X570 TAICHI - THE RYZEN 3000 MOTHERBOARD GIBBO & 8 PACK RECOMMENDS
Bought the taichi on release new and just purchased the gigabyte last week.
Still have the taichi in the box here, Might sell it with a 3900x I have due to going 5950x.
I see, yeah I also got the Taichi on release. Its been giving me lots of issues now with the BIOS even though I have flashed different versions. The motherboard just doesnt go to sleep and keeps my 3080 or 5700XT (tried both to see) with lights on when Shut Down for no reason. It never did that before, the only way to stop it is to shut down holding the power button. Im about to buy an X570 Unify.
Well i just flashed to 3.91 Beta using the Bios flashback method.
Loaded bios defaults then punched in my settings same as 3.80 and no issues.
Seems perfectly stable to me and I can see I have gained 250 mhz on all cores during Cinebench R23 and gained 1000 points.
Now at 29228 with just neg 15 on all cores with CO so that can probably be improved.
Thanks for the info, can you share the settings you ran in bios for this?
Onedrive link showing my bios settings
https://1drv.ms/u/s!ArMHGD-yylU7gdwSN4VfNOd0XekWuw
Setting PBO to manual seems to make the most difference.
Setting limits to motherboard unlike some other makes seems to make only a small difference.
I am using 300 for PPT, TDC & EDC.
From previous experience with my 3900X you can use specifically EDC setting to control your temperatures.
Too Hot lower EDC until your comfortable with cpu temps.
With PBO limits set to motherboard my EDC useage shows approx 220A
Set at 300 I have seen it go up to 292A and so far my temps are fine.
These are exactly the same settings as used on previous bios versions but 3.91 definitely gives 1000 more points in R23 for me.
Trying 3.80 with existing 3700X CPU after a CMOS clear too. For the first time in ages it seems to have booted fine with XMP profile (3600MHz 16-16-16-36). Doing some testing at the moment but could be promising...
Cancelled my 5900X order as still no stock in sight and I'll wait for more sensible prices.
Memtest was all fine after 4 passes but I still got some game crashes in the typical sensitive ones like PUBG. I'm guessing some voltage tweaks required?
My 5900X has a much stronger IMC than my 3900X, which is odd as I thought they used the same IO die.
I had some problems at first but managed to sort it. What I have learned is, the Taichi seem to pure more volts into the SoC than you think. So I was over volting which created my problems.
I seem to be having a few memory problems with this board, with the teamgroup 8 pack 3600mhz 16gb kit. on bios 1.6, if I run the memory at 3600mhz on the xmp profile, even with a 1800 mhz IF I get crashes in games such as fatal error-d3d device removed which freezes the pc and forza horizon 4 just crashes to desktop, no errors. Running the memory at 3200mhz however with the same IF, it never crashes. It's done this over multiple gpu's now, my old gtx 1080 and the new rtx 3070 with all kinds of drivers, using ddu every time. Windows memory test hasn't detected any errors, don't know if memtest 86 would be better or would a bios update help?
Bios 3.91 just realised that under PBO limits it now shows a disabled option which i am pretty sure was not there on previous versions?
Anyway just selected this and all cores of my 5950X now hitting 4950 and above.
Ok lets rephrase this.
AMD overclocking PBO limits Auto, disabled, motherboard, manual.
BUT just ran cinebench and back down to 26K plus with 61C peak
No load shows all cores peaking above 4950 which of course aint worth a damn really.
With manual all at 300 PBO limits max temps 80C and scores over 29K Cinebench R23.
I shall be going back to this I think.
Unless of course theres something else i am missing.
