I assume you just sold yours used and bought a new one right?
Bought the taichi on release new and just purchased the gigabyte last week.
Still have the taichi in the box here, Might sell it with a 3900x I have due to going 5950x.
I see, yeah I also got the Taichi on release. Its been giving me lots of issues now with the BIOS even though I have flashed different versions. The motherboard just doesnt go to sleep and keeps my 3080 or 5700XT (tried both to see) with lights on when Shut Down for no reason. It never did that before, the only way to stop it is to shut down holding the power button. Im about to buy an X570 Unify.Bought the taichi on release new and just purchased the gigabyte last week.
Well i just flashed to 3.91 Beta using the Bios flashback method.
Loaded bios defaults then punched in my settings same as 3.80 and no issues.
Seems perfectly stable to me and I can see I have gained 250 mhz on all cores during Cinebench R23 and gained 1000 points.
Now at 29228 with just neg 15 on all cores with CO so that can probably be improved.
Memtest was all fine after 4 passes but I still got some game crashes in the typical sensitive ones like PUBG. I'm guessing some voltage tweaks required?Trying 3.80 with existing 3700X CPU after a CMOS clear too. For the first time in ages it seems to have booted fine with XMP profile (3600MHz 16-16-16-36). Doing some testing at the moment but could be promising...
Cancelled my 5900X order as still no stock in sight and I'll wait for more sensible prices.
To be fair to Asrock my mem has always worked @ XMP settings. (3600. 16-16-16-36)
Mine wouldn't go on a 3900x but works fine on a 5900x must be IMC on the chip?
My 5900X has a much stronger IMC than my 3900X, which is odd as I thought they used the same IO die.
Bios 3.91 just realised that under PBO limits it now shows a disabled option which i am pretty sure was not there on previous versions?
Anyway just selected this and all cores of my 5950X now hitting 4950 and above.
