Oh, sorry, missed RAMDo you have the 2x16GB 3600C16 ram kit?
I do, 2x16GB 3600C16
The stuff bottom left
Thanks, looks like you hit all the silicon lottery's at onceOh, sorry, missed RAM![]()
Nah, the CPUs a bit of a dumpling compared to some using the curve optimizer. I just leave it at default (PBO auto) and the CAS14 / 1900IF as it results in low latency and cores are fast enoughThanks, looks like you hit all the silicon lottery's at once![]()
As it happens, yesI took these earlier to remember my settings when upgrading (then reverting) back to this A82 BIOS
BIOS settings DDR3800 / IF1900 / CAS14
32gb set gone up to £299 now...was on offer at £199 before with regular price around £239....they're just price gouging now and taking advantage.
Business will go elsewhere now.
YesI'm new to AMD so I just wanted to double check, will 8Pack Edition 32GB (2x16GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit be compatible with an 5600x on an MSI B550-A pro?
New AIDA64 stats with the 5800X
This is with SoC Load line calibration on mode 1, but limiting package power to 125W to keep temps low.Noice!
