I thought things had improved a lot since you wrote that with Windows 10 bringing out advanced colour support in version 1703 and they have improved on it in every version since?
Well, things did not improve, at least not for my non-HDR wide-gamut monitor. It may be, that if you enable HDR in Windows 10, then Windows will automatically convert SDR content to sRGB color space. Because that's what "Windows Advanced Color" is about, doing HDR. Not without its own issues, as even Dell suggests to turn the HDR mode only to watch HDR content. https://www.dell.com/support/kbdoc/...ynamic-range-is-enabled-in-windows-10?lang=en
EDIT: nVidia too: https://nvidia.custhelp.com/app/ans...iderations-for-playing-games-with-hdr-enabled
Unfortunately I can't test it myself, as I don't own HDR monitor. I'm looking to buy one, hence why I'm here
BTW, the part you quote is from a manual on how to write HDR apps, so it's definitely not applicable if you have turned HDR off in Windows. https://docs.microsoft.com/en-us/windows/win32/direct3darticles/high-dynamic-range
Are these the settings you guys keep talking about (I don't really understand what these settings even do
Don't know the monitor, but I assume that yes, that's the setting.
as Dell website says it only 31watts
