Not sure if it’s at all relevant but the G9 suffered from these issues but they’ve since been resolved with updates to monitor firmware and drivers.
Yes, I think the autodisabling of shadowplay/instant replay came about from the 8k update. I don’t think shadowplay properly supports 5120x1440. If you want to record, you have to set the recording resolution to 1080p and it will capture a downscaled video (but still at 32:9). From reading around I think that’s what shadowplay may have done automatically before the 8k update.
How can I sort this gap out without risking breaking anything?
although I can't say I relish the thought of insects getting in there
I would send it back for sure as that going to annoy you all the time and will also knock the value right down when it comes time to sell it..I'm not sending it back and risking getting another with missing pixels, although I can't say I relish the thought of insects getting in there during the summer, or a dust buildup.
It's not that visible from the front, only when you look down from the top. It just feels like the plastic trim somehow need fixing in place, but of course it's rigid when I press on it.
It's only the 500 squid model, so I don't mind buggering around with it a tad.
Not sure about the not breaking it part but it should sort the gap outHow can I sort this gap out without risking breaking anything?
Is there a G9 as well?Samsung are putting out a new model but I doubt it is any better.
Samsung Odyssey G7 with 4K / HDR1000 emerges
https://www.ces.tech/Innovation-Awa...s/S/Samsung-UHD-Curved-Gaming-Monitor-G8.aspx
Samsung Odyssey G7 with 4K / HDR1000 emerges : Monitors (reddit.com)
