- 21 Oct 2020
Installed the One UI update today. Massive improvement to the battery life. Two and a quarter hours SOT and I'm still on seventy percent battery. That's much more like it.
What screen protector are people using?
Looking at Whitestone dome glass..
Any noticed battery stats are borked , mine are I didnt notice till I read the news below fix worked for me
All Galaxy devices that have been updated to the final version of Android 11 and One UI 3.0 have a strange bug: They don’t show battery statistics ever since the clock struck 12 and we rang in the new year. In plain words, you won’t see any battery stats in the Settings » Device care section on your phone for January 1 and later, but if you change the date back to December 31 or earlier, it all goes right back to normal.
`https://www.sammobile.com/news/one-ui-3-0-battery-stats-2021-bug-on-galaxy-phones-fix
So with the new update there is the option to go into developer options and turn on the 'show refresh rate' so that you can see what refresh rate the screen is at during various scenarios. I turned this on and noticed that it is showing 120hz constantly and is not dropping when high refresh is not needed. This screen is supposed to adapt.
Can you guys try this and see if your refresh rate drops below 120hz when the screen is doing nothing.
I stumbled upon this while watching a recent Jimmy is Promo video explaining how to use 120hz adaptive in power saving mode, his screen showed 120hz when he was scrolling then back down to 60hz when he wasn't.
Great video by the way.
Edit:
Ok I think I found a workaround, for me at least, I found that turning off 'dark mode' and then changing the screen to adaptive, it seemed to work as it should, then enable dark mode again.
Another software update incoming, stability.
Same January 1st security patch.
How will the upgrade program work in regards to the lack of charger going forward? Don't they usually require I send it back?
