Caporegime
- 18 Oct 2002
- block 16, cell 12
Anyone able to give me some esc advice mine just blew in a puff of smoke.
Sure. What model was it in?
the motor should still be fine unless you can see any damage. 3200KV would be for a smaller, lighter such as 1/10 and the DRX is 1/9 scale don't know if it would have the torque and would probably get very hot.Thanks! Drx ve, orion r10 went pop.
Lookimg at a hobbywing ezrun mac10 120a, plus 3200kv motor combo.
If I replaced my motor and esc would I need to re think my pinion size? Stock motor is a 2400kv.
Running 3s.
https://www.ebay.co.uk/itm/Hobbywin...064353?hash=item23a14d78e1:g:A0EAAOSwgc1ar8sx seems decent enough or if you can wait plenty on Hobbyking.
Both pretty similar but one is waterproof.I see thanks for that! Any benefit if the sc8 vs the max10 120a?
The reason I'm looking at the combo is I've seen a deal inc programming car. Worst I could sell the motor off and keep the ezrun max10 120a with card would work out about 50 quid ish.
Programming ESCs is pretty easy just using the button on the device you just have to follow the beeps/flashes and most times the default setup is fine.
Anyone know about boats? Got some £20 amazon ones for the boys and they are having fun with them, I kind of want something bigger.. faster ..
We do have some boats. What sort of thing you looking for? Budget?
the carnage sounds decent but i have heard they can be a bit weak.
check out https://www.modelsport.co.uk/maverick-quantum-mt-1-10-4wd-monster-truck-blue/rc-car-products/1330752 as well, looks decent and there is a brushless one as well https://www.modelsport.co.uk/maveri...ium-truck-blue-orange/rc-car-products/1330755
https://www.msuk-forum.co.uk/forums/topic/243887-maverick-quantum-flux-mt-xt/ a lot of info here about it
more info on the carnage https://www.msuk-forum.co.uk/forums/topic/138437-ftx-vantagecarnage-owners-thread/#comments
Sorry I completely missed this post yesterday. Thank you for that, in the end I went for the FTX Outlaw Brushless.
It was a close call but I really didn't like the idea of that plastic shell on the Carnage, one YouTube vid said he'd been running it all of 2 minutes and wheelied the car catching the plastic on the road and completely shredding it. Anothee basically the same.
Now the outlaw, possibly not as refined or easy to drive, plus it's almost a given you'll need to replace the plastic drive shaft, but, it seems to take more of a beating if you roll it etc.
Plus it looks way cooler.
I'll let you know how I get on should arrive tomorrow.
Is there an RC car which is virtually indestructible?
I remember I had one which was essentially 4 large wheels with a thin chassis in the middle so if it flipped over it could just keep going.
If you rammed into anything it was essentially the tyres hitting it and just bounced back off it.
Is there a better equivalent of that today?
https://www.amazon.co.uk/dp/B085Q1R...mm_t1_dlT3_iebeGbDK6HJ00?_encoding=UTF8&psc=1
It was like that but much better probably cost around £80-£120 from Argos back in the 90's
was it a tyco rebound you had?
