 - 24 Mar 2011
 - Kent
Yeah I've read the mesh systems without dedicated backhaul (like the Deco M4) can do 500mbps with ethernet backhaul but without it, once on the 3rd unit the speed will have dropped to 120mbps.
Not a problem on the Tenda Nova MW3 as it only has 10/100 ports so 90ish mbps is the upper limit, with much faster wireless protocol between the units, so should be able to get 90mbps on all units. Which is fine for my use. Good value at £60 too.
OK, the wifi is shockingly bad, fair enough as I imagine most of the internal space is being used for the 5G antennas.
25ft away through 2 walls, I get this:
Move to within 10ft in the same room as the router and:
