We knew it could theoretically do it with some driver updates but a 22k score has arrived for the 6900XT on Timespy @ 2765mhz.
https://www.3dmark.com/spy/18120671
Is your GPU-Z up to date? There are better apps available for monitoring such as HWINFO64.I have been playing around with the MPT this morning ans have just got the result https://www.3dmark.com/3dm/58015446?
Score: 18,830
gpu score: 20,014
Cpu Score: 14,106
Now im wanting to reduce my power limit from what this is set too as temps were - 88 gpu and 109 hot spot
For some reason my gpuz doesnt show me fan usage at all is this normal?
Just remembered you are using an AIB 6900 XT.yeah gpuz is latest version 236
Ive never given hwinfo64 much time maybe i should.
I shall try and find a balance now for day 2 day use as dont want fans up all the time but for benching its interesting.
That last score i got was basically the same as my 3090 i have just sold.
I have some saved profiles you can try if you like. Just download them and load them into GPU Tuning. They were designed using the MBA design, so might be able to reduce fan speed for AIB models.
2300Mhz/2012Mhz 1.025v Power Saving 255W
2400Mhz/2112Mhz 1.050v Balanced 275W
2500Mhz/2112Mhz 1.100v Performance 300W
https://1drv.ms/u/s!AmfBfrWrCDQLuUkWrQHzxka5d96l?e=dEUtKO
Yup.These can just be imported into the AMD software, right?
Have you disabled Zero RPM fan control in Radeon Software?ive re installed the drivers and still no fan speeds being reported by hwinfo or gpuz?
Nice let me know how that goes.Perfect! Will be giving this a go later.
Nice let me know how that goes.![]()
Good to hear!
I dont have that option at all just fan tuning and then advanced control, then the max fan speed slider
I think i may have to reinstall, to see if it fixes the issue, the mpt tool shows the zero rpm as not ticked either and ive rebooted pc to make sure its set to off after re applying it weird
Good to hear!
I checked the Sapphire website and it does not list Zero RPM as a feature so looks like it is not supported with your model.
NITRO+ AMD Radeon RX 6900 XT 16G GDDR6 (sapphiretech.com)
Does Radeon Software list the fan RPM under load or idle?
The plot thickens.I've got Zero RPM option on Wattman and I have a 6800XT nitro though
The plot thickens.
Good to hear they were created on a 6900 XT MBA so should work well. Be interested to know if the other two work as well if you ever need more/less performance.@LtMatt those profiles are spot on mate. Balanced is the only once I've used but peak temps are lower and so far, after about 5 hours gaming, it's been perfectly stable.
