Assassins Creed Valhalla Bench Thread
Update for 1080p
Sam on
5600x 4750mhz
gpu 2760mhz/2130mhz mem
Driver 2.2.21
https://i.~ibb.co~/hMqJ6rW/1080p-val.jpg
Tried but unable to get more than 120fps at 1440p. Amd freq limit pulls back 6800xt all the time.
TBF to nvidia, you can undervolt the 3080 and 3090 massively. My tweaked 3080 is delivering better perf than an untouched 3080 and doesn't go above 300W now. Been very impressed with the 3080 FE in terms of temps and noise levels.
I have mine severely undervolted (0.7) and it plays the game smooth as butter. Loving the game, it has its bugs and crashes but impressed with it. Total system draw at the wall on the reduced settings is 350w, im not sure pushing the card yields better fps to be honest.
Update for 1080p
Sam on
5600x 4750mhz
Driver 2.2.21
Nice score, will update the thread shortly. I found the same at 1440P also, but I’ve not tried pushing the GPU yet.
Nvidia RTX 3080 FE@stock
AMD Ryzen 9 3900X@stock
32GB Crucial Ballistix 3600 MHz CAS 16 (4*8GB) RAM
1440P
1440P
Can you provide the GPU clock settings at stock as shown in the Nvidia Control Panel?
Scoreboard updated. :)
Update for 1080p
Sam on
5600x 4750mhz
Driver 2.2.21
Boost clock is 1710MHz, Memory clock is 1188MHz (19000MHz effective), not sure that's very accurate in practice though.
Boost clock is 1710MHz, Memory clock is 1188MHz, not sure that's very accurate in practice though.
You will likely be boosting in 1900 Mhz - 2000 Mhz range out the box at stock.
10.9% at 1080P. Didn't bother testing 1440P.
1080P
5950x
2570Mhz/2112Mhz
21.2.2
Smart Access Memory On
Smart Access Memory Off
1440P
5950x
2570Mhz/2112Mhz
21.2.2
Those SAM numbers are impressive in this games. 10% jump is nothing to sniff at!
I provide the clock speeds as i set them in Radeon Software, but in game is usually 50Mhz lower. What do you see in game?
Stock the boost behaviour can vary when not using a particular profile as it picks whatever voltage point it likes. However my posting of 2175Mhz is with one of my saved profiles with an undervolt and all steps after that at 2175Mhz so card sticks to that entire run during benchmark as its clockspeed.
Hmm, something can't be right there the memory clock when doubled is only 2376?
You will want to double it to get the same format as others :p so in same format as mine would be 4752 Mhz. depending on number person posts will be multiples of 2 basically.
Furry muff, jeez why can't it just be the number without all this multiplying Lol. All these different formats.
To make life easier AMD memory speeds will be displayed as whatever it is set as in software. I've updated the scores.
I know, I'm confused too. I think what I said is right but don't quote me on it. Effective clock speed is just marketing anyway.
1440p
91FPS average / 40FPS low
3090FE @ 2175Mhz / 5376mhz
9900k @ stock
Driver: 461.09
Ampere does not scale well as we drop resolution. AMD defo wrecks ampere in this game. Will be curious to see if it makes any difference when Addressable bar support comes out for Nvidia, decent gains it seems.
1440p
9900k @ stock
Driver: 461.09
Yep will be interesting to see.
Morning cold run with fan speed cranked. :D
5950X
6900 XT @2570/2112Mhz
21.2.2
1080P
1440P
