Care to explain yourself?So much irony.
Back when Intel used to make the fastest gaming cpus many people would recommend Amd over Intel even though Intel used to be faster in games. Why because Amd still made better all around Cpus. Better price, better multi thread, better power draw, better thermals.
Now we have Intel fanboys trying to use a similar argument.
Try read information properly that would be a start for you. Go back to post #321 to see where it starts before you troll anymore.Figure it out.
I've even recommended Intel CPU's for people why are just looking for the best gaming CPU's.
Its turned on its head now, Intel can only keep up if the GPU plays a large part in the performance, which is why you see a lot of high GPU demanding games more or less on par with eachother when it comes to Zen 3 vs Intel.
Take the GPU out of the equation and Zen 3 is miles ahead.
the guy seems desperate to defend his cpu... has his blinkers on i thinkthe guy seems desperate to defend his cpu... has his blinkers on i think
I beg to differ.
I would never recommend an Intel Cpu unless it’s on par with performance and significantly cheaper. They are a scummy company as far as I’m concerned.I've even recommended Intel CPU's for people why are just looking for the best gaming CPU's.
What i will say is something like a 9700K is actually a good all rounder for its price, it is quite capable and its cheap, like Zen 2 was, but Zen 3 is a better CPU, a much better CPU than anything Intel have right now, full stop.
It is on par with performance.I would never recommend an Intel Cpu unless it’s on par with performance and significantly cheaper. They are a scummy company as far as I’m concerned.
Use your brain, of course you haven't.pick up a dictionaryi haven't defended anything
and more expensive motherboards
but more expensiveand more expensive motherboards
You're beaten by a 5600X, by about 20% when the GPU is not the bottleneck.
Not good enough for me. I have a 3600 and that’s good enough for what I need, I don’t chase every extra frame.It is on par with performance.
I know. Just to be clear I don’t really care what people choose to spend their money on or which cpu is the bestest. I buy what I consider is the best bang for buck at the time I couldn’t give a monkeys about 120fps vs 125fps.That's fine.
Fair enough I bought the 10900k after hearing a lot of people having trouble setting their new ryzen cpus up (I'm not saying that ryzens are crap as I know that a lot of people also had little issues getting theirs working). Plus the fact I play some unoptimized games, some not so brand new games and play less e-sports titles so I bought the 10900k.I know. Just to be clear I don’t really care what people choose to spend their money on or which cpu is the bestest. I buy what I consider is the best bang for buck at the time I couldn’t give a monkeys about 120fps vs 125fps.
Good for you. Can we stop this whole my cpu is bettterer than your cpu now.Fair enough I bought the 10900k after hearing a lot of people having trouble setting their new ryzen cpus up. Plus the fact I play some unoptimize games and some not so brand new games and play less e-sports titles so I bought the 10900k.
