- 14 Aug 2018
IIRC the 10700k scored the same as the 10850K in Puget's Prem Pro benchmark which I found slightly anomalous as that is 8cores v 10cores, though should there be little difference between them then you could save yourself the odd ~£60 and put that towards some decent 3600Mhz memory or good size SSD, as they will also have an impact. Much more so the SSD.
