- 30 Mar 2016
- East Lothian
Got as far as downloading the files last night but chickened out...
I am expecting mine to say something like "sorry, wait this is a CPU?" ha. I will try and do it this weekend to see though.
Turn your block the right way round and it will be fine![]()
I got bronze sample on PBO then switched to an all-core -10mv and got this:
AMD Ryzen 9 5900X 12-Core Processor
Max temperature: 66.4°
Energy efficient: 3.86
Your CPU is SILVER SAMPLE
Recomended CCX delta: 225
Theoretical maximum CCX delta: 250
Recomended values for overclocking (P1 profile):
Reference voltage: 1175 mV
Reference frequency: 4375 MHz
Recomended values for overclocking (P2 profile):
Reference voltage: 1275 mV
Reference frequency: 4500 MHz
Recomended values for undervolting:
Reference voltage: 1000 mV
Reference frequency: 4025 MHz
I disabled PBO etc. to run diagnostic step and it said mine was a Silver Sample.
What does it mean, realistically?
Bronze = Good
Silver = Better
Gold = Great
How long does this run for?
What are you all using for cooling? I had to turn all the fans up to avoid it thermal limiting and it still hit 78c. I've got a Corsair H150i Pro XT, I shouldn't really be having this problem.
How's your case airflow? Is the H150i getting enough fresh air?
Kind of makes a mockery of awarded label then doesn't it. I mean, it's more a measure of how optimal your conditions are for the chip than the actual chip itself isn't?It depends on Temp i had a Bronze sample last night now its Gold after my temp when down to 62 from 82 last night just turned my fan profile up.
