- 23 May 2006
Worth a punt as I really don't like the stock or the silicon one I bought for it.
Have raised a request and will see what they come back with
Can't argue with free.
If it's as good as the reverb G2 one it's amazibg
Thank you, mine is on the way.
https://youtu.be/zRkmIUc-OPc
Good stuff,
ORDER STATUS: Processing
EST. DELIVERY DATE: Apr 12, 2021
Just got mine, anyone on here use it and wear glasses? Noticed a note in the instructions saying that it's not compatible with the glasses spacer...reckon the extra foam will provide enough distance?
Use the thick foam, should work, depending on your glasses ....
