- 6 Jan 2013
- Rollergirl
@Grayfox_83 considering the issue with the fan and the fact you are having difficulty using the BIOS update tool, you could load Afterburner and move the slider down until the fan noise is acceptable. Check at that point whether the card temperature is acceptable. As I previously posted, do this with the case side panels removed to simulate better air flow.
Unfortunately you might end up having to conclude that it's just a poor quality product, which is a shame considering the price you paid.
) Undervolting helps and the later BIOS's have a higher power limit.
