Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
What a pain in the **** modern cars are. I bought some new headlight bulbs and reverse light bulbs for my 17 plate Ford B-Max so had a look at the owners manual and went out to swap them over. First thing I noticed is that my head and tail lights are different to the ones in the manual so that was useless. With a great deal of difficulty due to the engine bay being so bloody cramped I managed to change the low beam bulbs. After much trying and cut knuckles I gave up on the high beam bulbs as I just can't get in there. Went around the rear and popped the tailgate only to find no obvious way to get to the bulbs. After much searching I found a seam in the trim and pulled a piece of the fabric back to find a small hole barely big enough to get your hand in. You have to undo this fastner by hand which has a heavy duty spring on it to remove the whole tail light. After much cursing, sore fingers and more cuts I got the damn thing undone only to find I had to go get a screwdriver to remove another cover on the light unit to get to the bulbs. Once removed I discovered that I had the wrong bulbs. The ones I had which were supposedly the correct bulbs for my car only had a single contact on the bottom while the actual ones I need should have two (so much for putting your reg number in and showing all the correct bulbs for your car
). With more cursing I put the damn thing back together again and that was a wasted 65 minutes in which I only managed to change a pair of dipped beam bulbs. What a nightmare!! I understand now why some people take their cars to a garage to have the bulbs changed. I now have to find a guide to see the easiest way to change the high beam bulbs and I suspect it's going to involve removing the headlight unti.
